Quick question on fuel screw (08 WR450)
3 replies to this topic
  • jj86
Posted March 09, 2013 - 03:08 PM
I'm changing out my fuel screw. I removed the stock brass screw and all I see is the spring in there. It does not look like there is an O-ring in there. Is that right? All carbs I've worked on in the past also have an oring on the screw as well.
Hoping for a quick answer as I'm planning to go back together tonight.
THanks!
JJ86
  • MANIAC998
Posted March 09, 2013 - 04:29 PM
Yes, there should be an o-ring in there. They sometimes get stuck in there. Are you sure there is nothing in there?
  • Pooley
Posted March 09, 2013 - 04:38 PM
Check for a washer too. Typically there are all 3, spring, washer and o-ring (in that order).
  • jj86
Posted March 09, 2013 - 10:23 PM
Yep, just checked. You were right. There was washer and oring stuck in there. Stuck a paper clip down in there and fished them out. Thanks, wanted to make sure I had that right before putting it back together. Pulling the carb on this bike is not much fun!
