2012 YZ450F TDC
2 replies to this topic
  • counteru
Posted March 08, 2013 - 10:01 AM
I need verification that I have my bike at correct position in order to check my valve clearances. Everything I read and seen shows the cam lobes to be pointed away from each other. I am thinking that since the exhaust and intake cams are reversed on these newer yz f's that the lobes should be pointing toward each other. Is that correct? I have rotated the engine counter clockwise many times and lined up my cams for TDC , and my timing mark, according to the manual and each time I make the correct alignment the lobes are pointing toward each other. Pic below:
Uploaded with ImageShack.us
So, ya I think I have it right.... 35 hours on the bike and the valves are still @ spec clearances btw. That is if I have the cam lobes right :excuseme:
Posted March 08, 2013 - 12:27 PM
I knew this would happen eventually. :smirk:
With the old engine (Gen 1 & 2), the exhaust cam was in front, and at TDC on the compression stroke, it points forward and up. The opposite is true of the intake; it was in back, and points rearward and up at TDC on compression. Away from each other.
Now, have the cams switch places. See?
  • counteru
Posted March 08, 2013 - 09:01 PM
Ya I worked on a lot of older models but not on any of these newer ones! Just wanted Clarification! Thanks
  • Hot  113 replies
  • 5 replies
  • 10 replies
