crf 80 stalls when choke closed
6 replies to this topic
  • alabamadave
Posted March 07, 2013 - 08:35 PM
Guys
I have cleaned the carb,pilot jet,main jet and still when I close the choke the bike dies. What in the world could it be? I have tried to idle it up and then close the choke and still dies.
things that make you go hmmmm!
Thanks
Alabamadave
  • KRANNIE
Posted March 07, 2013 - 08:36 PM
You can't clean a pilot jet. Replace it.
You probably have the passage above the pilot jet still clogged.
Use monofiliment wire.
  • 87XR250R
Posted March 07, 2013 - 11:06 PM
Money on the Pilot jet like the above post. Any decent shop should have a new one, if not a soak in berrymans chemtool, and a wire from a brass wire brush should fix it up.
  • shagger
Posted March 08, 2013 - 04:46 AM
Gun clearer works pretty well too.
  • MCRIPPPer
Posted March 08, 2013 - 10:37 PM
it is normal for a bike to not run with full choke. if it stalls when you take choke off, then you are too lean.
  • clintsmx
Posted March 09, 2013 - 05:07 AM
if your still having trouble after cleaning/replacing the pilot jet then you might want to check for air leaks around the intake manifold.Those o rings are prone to leaking. Also make sure you have decent flow from the fuel valve and that its making it to the float bowl.
  • socalxr
Posted March 09, 2013 - 08:42 AM
Are you talking about on start up or after it's already warmed up?
Top Speed of an XR200 by Yamiha
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
  • Hot  49 replies
xl100s vs xr100 trans difference? by CarmanCRF
Is a atc200x crankcase the same as a xr200 ? by LeeJosph1975
  • 8 replies
XR100 Bog and Backfire by qwika
  • 3 replies
Xr and crf 80/100 by Austen-cs
  • 3 replies
