To oil or not on your O or X ring chain
Posted 05 March 2013 - 03:44 PM
Posted 05 March 2013 - 04:05 PM
The need to 'heat soak' a chain in oil is not really needed anymore.
The point of an oring chain is to keep water and contaminates out of the pin mating surfaces, and hold in some of the lubricant.
I don't think putting a o-ring chain in hot oil would be good for the chain, for a couple of reasons: Hot oil has strange properties. It acts like a solvent, and actually attracts dirt and contaminates.
Neither of these thing are any good for the o-ring itself, which is good up to about 150 degrees. After that the o-ring starts to fall apart. The oil you are heating up is probably closer to 350 degrees.....!
The MOST important part of chain maintenance is the quality of the chain and sprockets, and alignment.
If any one part is worn, the rest will wear out to match, in short order.
If the rear wheel is not perfectly aligned, you will wear the chain out much faster.
After that, you keep it clean, use NO greasy lubricants, and eliminate water after washing the bike (like with WD-40), and then eliminate the WD-40 (which will act like a solvent if you leave too much of it on the chain) with light chain oil or Chain Wax.
I prefer the Chain Wax to Chain oil.
There will be many different opinions on chain maintenance.
I've tried a bunch of different methods, and this is what I now stick with.
Posted 05 March 2013 - 05:36 PM
My method of chain maintenance is to use simple green and a "Grunge Brush" to get all the dirt and crud off the chain when I wash the bike after each ride. Rinse it off and then use WD40 to get rid of the moisture on the chain. Once that is done I take a clean rag and dry the chain removing the WD40 and any water still on the chain. Then I apply a good coat of chain lube and call it good.
There are many good chain lubes out there but I have been using Honda chain lube for years and really have no reason to change. My chains last forever and the lube does not attract dirt and leaves no mess. This isn't a debate over what chain lube is best, its only my preferance based on my own experience and availability in my area. Just don't tell my Yamaha that it gets Honda chemicals!!!
Posted 05 March 2013 - 05:51 PM
After a ride I stop at a car wash on the way home and hose the bikes off. Just try not to spray directly at the chain. By the time I get home the wind has dried the bikes off.
I then take 30 seconds to spray some el-cheapo chain lube (I think I got my last can from Lowes for $1.50) on the chain before tossing the bikes in the shed. After that I just forget about it and ride. My chains last for years and years.
Expensive chain lube is a scam. It'll be gone 30 seconds after you start riding. At least in all the sand/mud where I ride.
Edited by DDACT, 05 March 2013 - 05:53 PM.
Posted 06 March 2013 - 04:14 AM
Posted 06 March 2013 - 06:14 AM
Posted 06 March 2013 - 08:03 AM
Wash the bike, dries in the garage and add WD-40. Add WD-40 before and after rides. All my chains o-ring and non o-ring have lasted a long time. My last bike had the stock chain and gears for 3800 miles in DS dusty lime stone roads to clay mud trails. WD-40 cleans off easy with soap and never builds up.
A buddy of mine places his chain in a oil tank with a vaccum drawing out all the air. You will be shocked to see all the air coming out even after the oil was heated. He would let the chain sit in the vaccum for the winter. Swears by this, I am too lazy and get good milage out of my equipment to worry about it.
Posted 06 March 2013 - 08:10 AM
Posted 06 March 2013 - 09:36 AM
Posted 06 March 2013 - 11:15 AM
you are doing more damage than good by doing this with a O or X ring chain
You only need to keep the O-rings wet, to prevent wear and hence leakage of the lubricant held inside the chain by the o-rings
Once the o-rings leak, and the lube comes out of the chain, the chain will need adjusting after every ride and at this point should be tossed in the bin.
Posted 06 March 2013 - 02:56 PM
allterra, on 06 March 2013 - 09:36 AM, said:
Front sprocket is hooking pretty badly............
Edited by Krannie, 06 March 2013 - 02:57 PM.
Posted 06 March 2013 - 03:13 PM
Krannie, on 06 March 2013 - 02:56 PM, said:
it is certainly getting there. I hope I can get through the spring on it. too bad they don't make a real hard front sprocket. this one hasn't even gone a full year yet. Worse than my YZ but than again I did not ride that to and from the trails or to or from work. I had the street bike for that.which since I got this WR I have not been in any hurry to put back together. I prefer the dirt but need the asphalt as well. I am on 2 wheels when ever I can.
Posted 07 March 2013 - 04:10 AM
Posted 07 March 2013 - 10:29 AM
MANIAC998, on 07 March 2013 - 04:10 AM, said:
Err, you need a bigger rear sprocket to compensate for a bigger front sprocket
Posted 07 March 2013 - 10:44 AM
Impressive deduction. Yes, that is a 14 and as you can see in the pic I am running a 48 in the rear. I am thinkinking of going with a 16 if it will fit with the case saver.
Edited by allterra, 07 March 2013 - 11:05 AM.
Posted 07 March 2013 - 12:07 PM
Follow us:
