07 yz450f fresh rebuild, can't start
1 reply to this topic
  • wiseone 910
Posted March 02, 2013 - 06:42 PM
I have a yz450f I just done the top end on, I put a new cylinder, piston, rings and went through the head and cleaned it up. I have fire, fuel, valve clearance is good, timing is good, the only thing is the compression test, I can't get a good reading because of the auto decompressor. What kind reading should I get, when I do compression test I get around 65-70 psi, on a leak down test I get 15-20 psi leakage on a fresh engine. I've tried starter fluid and I've kicked the shit out of it, and it will not even hit a lick, it won't do nothing, tried new plugs, set ex. Valves at .010''. Someone told me check the tps, could cause the bike not to hit at all? I need help I don't know what else to check other than electrical issues
  • Krannie McKranface
Posted March 02, 2013 - 07:56 PM
Define 'done the top end'...........
Did you replace the valves?
Did you have the seats ground to match the new valves, and put in new guide seals?
65+ psi is normal with auto decompress.
..but how long does it last?
You should get zero leakage on a new engine....and where do you hear the leaking? I'll bet it's in the intake tract, from a leaky intake valve.
