Edited by Barra8, 28 February 2013 - 12:31 AM.
TTR-250 Teikei Y30P Re-build thread
Posted 27 February 2013 - 11:36 PM
Posted 28 February 2013 - 05:30 AM
Oh, by the way... I've seen lots of info on line about rejetting the Teikei carb and most folks seem to have trouble finding jets for them, using Mikuni jets, etc... I was poking around on line and found this website:
http://www.motorcycl...n_Jets_C785.cfm
Posted 28 February 2013 - 08:40 AM
That for the link
This should explain your question..
Rubber Grease
PBR rubber grease is a high performance castor oil based grease designed to preserve and lubricate plastics, rubber and components such as o-rings, valves, diaphragms, cups and seals. It is available in a range of pack sizes for both retail and the workshop.
Edited by Barra8, 28 February 2013 - 08:47 AM.
Posted 01 March 2013 - 05:08 AM
Posted 02 March 2013 - 09:39 PM
The idle mixture screw was out 6 1/4 turns too. I assume on these carbs that it adjusts the amount of fuel, as apposed to other carbs that adjust the amount of air. Maybe thats why it started so easily, with no choke even when cold. Maybe that accounts for the black in the pipe too.
Posted 04 March 2013 - 02:24 AM
If it was the standard Teikei main jet it would have the number stamped on the side of the jet.
If you zoom on this pic you can see that the main jet have numbers on it,the nozzle doesn't.
Have you tried dropping the needle down? If not it's worth a shot.
If you do have a standard #137 main jet it is quite confusing as to why it is too rich. I do seem to find that people from other countries IE. UK,USA etc. need a smaller main jet. The fuel quality defiantly is a biggest cause of the confusion.
I will be uploading more to the link once I can take pics . I lost my phone & the camera that I have is no good for closeups,but thats another story.
Posted 04 March 2013 - 12:38 PM
I need to order a few parts, so I should have time to dink with the carb a bit. Found out my petcock had started leaking when I removed the carb... so I need to order a rebuild kit or a new petcock. Plus a few o-rings and small parts for the carb. Since I'm in there I may as well replace the bad ones. Mainly the one on the float valve seat (which is only available as part of a float valve kit) and the tiny one on the idle mixture adjuster screw.
Posted 05 March 2013 - 09:36 AM
Carb is all back together and clean... waiting on a parts order for the parts to rebuild the petcock until I reinstall it. Weather turned to crap again anyway.
Anyone ever try the fairly inexpensive Tusk brand bark busters? Are they decent? Just wondering before I order them...
Posted 05 March 2013 - 03:12 PM
Never tried the Tusk bark-busters but you can buy the genuine Yamaha ones HERE
Not sure what you meant by this
Hard to notice, but there is a shallow polished groove in the center on one flat!
I think you mean that the jet number has been removed. If so this tells me that someone has drilled & milled the main jet.
ps. I have been busy with my site lately so I haven't had much time for anything else. Just been trying to make it more readable & owner friendly .You are invited to join if you wish?
Edited by Barra8, 05 March 2013 - 03:58 PM.
Posted 05 March 2013 - 06:51 PM
Just wondering about the quality of these handguards... but I think I'll try them out.
http://www.amazon.co...r/dp/B003O6BFOC
Can you give me a link to your website?
Posted 05 March 2013 - 07:57 PM
If there is no markings then someone has drilled & milled & why they removed the jet size. I highly doubt that it didn't get marked properly in the factory.
I left you a link before. This is the carby section... http://ttr250world.w...re-build-thread
My home page http://ttr250world.webs.com/
Edited by Barra8, 05 March 2013 - 11:55 PM.
Posted 06 March 2013 - 06:13 AM
Oh, ok... I remember the link, but I guess I didn't know that was YOUR website! Cool... I'll have to stop by and sign up!
Posted 06 March 2013 - 11:07 AM
I have only made it recently so it may look a bit UN-professional (English is not my favorite subject lol) ATM. A lot of the info was taken from my re-build thread & I was in a rush at the time so it's not all peaches & cream (if you know what I mean). It also has been so long since I have tried to write anything important that I have forgotten many of the ''tricks of the trade''. It should nevertheless be readable though lol
I could make you an admin if you like? maybe you could edit my bad grammar & punctuation etc lol
Posted 06 March 2013 - 01:11 PM
I noticed the site looked new... nice job so far! I have a question I might ask there... just something that I've been wondering about the ttr250.
Posted 06 March 2013 - 04:16 PM
Ask any question that you want (within reason),if I can answer it I will do it promptly. I go on there everyday (that I can) so I'm never too far away.
I forgot to say thanks for your kind feedback about my site & your questions asked. This helps me to recognize where & what info is missing.
Edited by Barra8, 06 March 2013 - 06:02 PM.
