How to bleed the shock of a 2010 YZ450F
4 replies to this topic
  • ELPRIDES
Posted February 26, 2013 - 08:08 PM
Hi guys!!!! Today I'm work on a Shock of a 2010 Yz 450f and I noticed a sound like an an air leaking when I pull in the stroke, then when the stroke returns it sound like rubbing against something, so I dissasembly the shock like 3 times and bleed again, what do you think guys it happens ??????
  • Stu2
Posted February 27, 2013 - 09:46 AM
It could just be air in the shock, what bleed procedure are you using ? DaveJ's procedure is apparently the one to use
Posted February 27, 2013 - 10:04 AM
Dave Johnson's method:
http://fullthrottlem...OCK_REBUILD.pdf
Originally written for the more familiar shock that has the reservoir parallel to the body, but works on the new ones, too. It's not unusual for a shock to make "some" noise.
  • mach1jonny
Posted March 02, 2013 - 07:05 AM
When I completed the revalue and fluid change on my shock (used Smart Performance parts and fluid). To make sure all air was out I tilted the shock a bit. It is tempting to use to much stroke on the shock when bleeding, which will build up pressure and give you a bath in the fluid.
  • mach1jonny
Posted March 02, 2013 - 07:06 AM
Sorry - I forgot to add, this is not a fast procedure just take your time and have plenty of shock fluid
  • Hot  28 replies
  • Hot  47 replies
