Grey wire help! Please
12 replies to this topic
  • Mark831
Posted February 24, 2013 - 05:45 AM
I have a WR450 2008. I planned to do the free mods only to find the AIS removed and blanked, the baffle removed from the exhaust and a throttle stop screw approx 30mm long in the bag of spares I got when I bought the bike second hand. So, I checked and can see the grey wire is still attached . If I disconnect the grey wire do you think I will need to re jet etc or do you think I can take a chance and figure it's been done by superior powers of deduction? Any thoughts on this would be appreciated.
  • MaxPower
Posted February 24, 2013 - 12:06 PM
pull that thing now.
  • Krannie McKranface
Posted February 24, 2013 - 12:16 PM
The gray wire does not affect fuel/air mixture, only the ignition timing curve.
  • Mark831
Posted February 25, 2013 - 03:32 AM
Thanks Guys. I'll pull it and let you know how it goes!
  • Mark831
Posted September 27, 2013 - 02:35 AM
Pulled the grey wire. Can't say I noticed any thing significant. So I'll take that as a good thing and trust everyone's good advice.
Thanks gus
  • zlathim
Posted September 27, 2013 - 07:12 AM
Thanks gus
I appreciate the feedback.  I've been debating whether to disconnect the grey wire on my bike, but it runs great as it is so I haven't bothered to mess with it.  Now I might never pull it.
  • Mark831
Posted September 28, 2013 - 06:29 AM
I'm probably not ridding hard enough yet to notice the difference. I'm sure those that do can appreciate the advantages better than I can. Anyway it's off and there' s no need to reconnect it. It's a matter of choice.
  • Hawk1107
Posted September 28, 2013 - 11:31 AM
I have and 07 wr450. That I put the yz450 carb kit on. It gets rid of the grey wire and if yours has it all the smog stuff on it.. Kit comes with everything new jets/seals. Now it runs great and is a lot more responsive
  • Motomike1
Posted September 30, 2013 - 03:57 PM
stupid question probably, but does pulling the gray wire help keep the engine running while i powerslide the rear in turns.  my '09 450 will stall even when i pull the clutch in and lock up the rear brake....killed me in my last enduro race...
Posted September 30, 2013 - 04:16 PM
That's because all WR clutches drag.
You can fix your clutch drag, or just change your riding style...
Don't ride it like a KTM (heavy rear brake to turn with the rear wheel).
  • alexszl
Posted December 23, 2013 - 11:53 AM
I have a on/off switch connected to my handlebars routed to the grey wire. When on YZ mode it has more power at higher revs but tends to choke off when rock crawling in first gear. That's when I swith it to WR mode it goes like a tracktor without stalling so easily but as I hit the straights the power fades quicker into the revs. You really have to be in 'race' mode and give it full throttle to feel the YZ power above the WR power. I just flick the swith on the go and can't realy say I can feel an adjustment in the cdi mapping change-over. Best of both worlds.
Alex
  • zlathim
Posted December 26, 2013 - 11:58 AM
Alex
Cool idea!!
Posted December 29, 2013 - 06:32 PM
Until your jetting is correct, and your TPS is adjusted correctly, you will not feel the gray wire change.
