So will it or won't it?
5 replies to this topic
  • Tford713
Posted February 21, 2013 - 05:10 PM
I've read a couple threads on this before and some say yes it will and some say no it won't. I'm looking for a new slip on exhaust pipe for my yz426f my question is will the slip on exhaust pipe from a 03-05 steel framed yz450f bolt on with no problems?
  • Yamaryder29
Posted February 21, 2013 - 05:40 PM
Yes, it will fit. I had a fmf slip on from an 05 that I fitted on my 2000 yz426
  • Tford713
Posted February 21, 2013 - 05:57 PM
Awesome thanks.
Posted February 21, 2013 - 07:22 PM
Pipes that are built in 3 pieces like the FMF's, header, mid pipe, and a separate silencer, have a better chance of fitting correctly than do pipes like the DRD that have the muffler welded to the mid pipe. In most cases, the misalignment that occurs is no more than annoying, but once in a while you run across a newer pipe that just won't quite work.
  • Tford713
Posted February 21, 2013 - 10:02 PM
Ok. I'm just going to pull the trigger and hope it works out. Thanks
  • essex426
Posted February 21, 2013 - 10:49 PM
I fitted an fmf Q pipe and header from a 450 to a 426,had to enlarge the bolt hole in the subframe slightly.
