Water Temperature Sensor
4 replies to this topic
  • diekatze450
Posted February 14, 2013 - 03:57 AM
Just bought trail tech´s temperature gauge. The sensor is to be plugged cutting a water hose.
My question is in wich hose it would be better to use: before the water gets the radiator, where temperature is higher and the reading would be more straight from the engine, or after the radiator, where temperature is lower but perhaps i get a better indication of the whole cooling system.
thanks!
  • William1
Posted February 14, 2013 - 07:21 AM
The feed hose going to the radiator is best, the closer to the engine, the better.
What matters is the engine temp, not radiator temp.
  • L. Euler
Posted February 14, 2013 - 08:30 PM
I found that the wire was not long enough and had to install on the radiator return. After running that way for a while I think I like knowing the effectiveness of the cooling more than the engine temp since looking at the coolant stream will never tell you your engine temp anyway.
  • diekatze450
Posted February 15, 2013 - 07:40 AM
Rad vs Engine: 1-1
I also see slightly different different hose diameters.
which sensor size are you using?
  • William1
Posted February 15, 2013 - 01:33 PM
Trail Tech has extension cables.
