09 wr450f won't turn on!
15 replies to this topic
  • Mauro Gonzalez
Posted February 13, 2013 - 02:22 PM
Hi guys, I have a huge problem with my bike, a few months ago I did change the oil but I pour way to much oil on it, rode it for like 15min shut it off and then like 2 hours later tried to turn it on but it did't, that extra oil blow all the way down from the head's hose to the air filter, I did the oil change again and pour the correct amount it should has, cleaned up all the messy on the air filter box and throw a new air filter and spark plug on it, then tried to star it on but it didn't I checked everything I could check (I'm not a master on a dirt bike issues) but it still not turning on, cuz I was tired of it and I had a new top en kit on my garage I did the new top end and it's still not starting
Edited by Mauro Gonzalez, February 17, 2013 - 09:37 PM.
  • Bandit9
Posted February 13, 2013 - 06:42 PM
It won"t turn on or it won't start?
  • Mauro Gonzalez
Posted February 16, 2013 - 06:03 PM
It won't start!! I have checked almost everything and it seems to be all ok!!
  • Bandit9
Posted February 16, 2013 - 06:14 PM
Start with the basics....Are you getting spark? Is it turning over?
  • allterra
Posted February 16, 2013 - 08:24 PM
Will it turn over?.... Will it start with the kick?.. ..did you accidentally knock it in gear?....is the battery still good and connected?
  • Mauro Gonzalez
Posted February 16, 2013 - 10:45 PM
yeah, I'm getting spark, I took it out and kick it a few times and you could see the spark getting fire pretty clear! I tried pushing start it and it did start just for like 3 seconds and then it died again!!
  • Mauro Gonzalez
Posted February 16, 2013 - 10:53 PM
there's spark, there's gas. there's compression but it still not starting!! it got brand new top end and I did clean and jetting it to the correct sea level, new spark plug as well and it still completely died!! if the battery isn't in a good working condition it won't start??? that's the only thing I've not checked yet and it's death!
  • allterra
Posted February 16, 2013 - 11:35 PM
With your last post I believe you are down to gas and timing. With you having said it ran for 3 sec after a bump start I am inclined to say gas. I would drain the bowl and make sure it is good gas and the bowl refills. If it refills with good gas then it is in the delivery system. Oh just in case however in likely is the gas turned on and gas and air filters clean.:unsure:
  • Bandit9
Posted February 17, 2013 - 05:56 AM
What about timing with the top end job? Or what about the hot start plunger?
  • Krannie McKranface
Posted February 17, 2013 - 07:37 AM
Need more details to diagnosis cancer from a distance....
  • Mauro Gonzalez
Posted February 17, 2013 - 09:37 PM
There's a brand new top end, brand new spark plug, brand new air filter, checked the valve lap, cleaned the head, checked the valve clearance, cleaned and new jet on the carburetor, triple checked the timing and everything seem to be ok but that shit still not starting!!! I really don't know what to do, there's compression, there's gas and spark on the spark plug as well!!! It was running perfect before I did pour way to much oil on it and then rode it for like 15min, shut it off and after that I couldn't start it never again!! if the battery is death, it won't start?? that's the only thing I haven't touch and it's death!
Edited by Mauro Gonzalez, February 17, 2013 - 09:42 PM.
  • MANIAC998
Posted February 18, 2013 - 04:50 AM
If the battery is dead, it will be a bear to start at the very least. Last summer that happened to me, and I maintain my bikes constantly. Luckily I knew the battery was going dead so I had a new Lithium on order and it came in the day that I needed it. When the bike wouldn't start, actually wouldn't even try, I threw the new battery in and it fired instantly and ran perfectly.
  • Bandit9
Posted February 18, 2013 - 05:33 AM
Jump your battery off your truck or car. See if it will run while connected to car battery. If it does, then your battery is dead dead.
Edited by Bandit9, February 18, 2013 - 05:36 AM.
Posted February 18, 2013 - 07:30 AM
Please explain
If you have run the battery down to zero, it won't kick start.
  • allterra
Posted February 20, 2013 - 12:02 AM
Please explain
If the battery is dead but still connected it MIGHT start, but not run well or long. Most "DEAD" batteries have a little bit of "juice" in them. However if the battery is shorted or not connected it will not start or run. That is one of the reasons why people that remove their battery to save weight need to get a battery bypass circuit.
  • William1
Posted February 20, 2013 - 09:00 AM
When you over filled, excess oil was vented into the air boot. You noticed this and cleaned the air filer. However, what did not get cleaned out were the slow and main air jet passage ways that start at the carb bell. No doubt they too, are oil filled.
The bike will kick start with a dead battery. the stator does produce more power than the CDI requires at idle However, it is not a steady flow of current and accordingly, the engine may stall from time ti time
Clean out the carb, change your battery.
