2011 YZ450F
4 replies to this topic
  • xXNewfie709Xx
Posted February 10, 2013 - 04:27 PM
Hey guys,
My friend is looking at grabbing this 2011 YZ450F for a real good price but he would want to make it street legal here in Canada. Has anyone ever made a YZ street legal here? And if so what kit would you recomend? I seen one at http://www.bajadesig...ort-kits/yamaha that looks nice but it mentions something about the stator called stator rewind. What does that mean? Would there be antying else he would need to know before he buys this bike? Thanks alot!
  • wweagleflyer
Posted February 10, 2013 - 04:52 PM
I am sure you will get much more knowledgeable answers than I can give here on the forum, but I can tell you what the stator rewind is. The stator is part of the magneto which generates electric current for the ignition system. For motocross bikes like yours, the magneto is designed to be light and provides only the electric power needed to run the engine's ignition system. For a street legal bike, you need enough power to run a head light and a brake/tail light at a minimum. In order to provide this added power, the stator in your magneto (the flywheel with magnets is the rotor part of the magneto) will need to get rewound with the insulated conductor (called magnet wire) so that there are more turns in the winding (which generates more current). So rewinding the stator means that you have to remove and then rewind the coils of wire on the stator so that your bike will generate enough electrical current to run the lights required to be street legal.
Scott
  • xXNewfie709Xx
Posted February 10, 2013 - 05:00 PM
Scott
TY much, I never knew this.
  • sergey
Posted February 11, 2013 - 06:37 PM
No need to rewind anything, as 2011 yz450f stator already produces enough DC power to run everything required to make it street legal.
  • atropine
Posted February 11, 2013 - 11:11 PM
The stator rewind was required for pre-2010 YZ's. As mentioned above, 2010-current YZ's have a much larger DC power output in order to run the fuel injection system. I think Baja Designs makes a plug and play wiring harness that plugs into the factory ECU harness and runs to both a handlebar switch and a lead to plug into one of their LED headlights. The switch has to be off while starting the bike due to the large power consumption necessary to start the bike initially. Once the bike is running, the power consumption is much less and the headlight switch can then be turned on. Not sure if anyone has wired one up to run turn signals and taillight/brakelight/horn, but I would sure think it is possible.
