I"m in.....
68 replies to this topic
  • beezer
Posted March 04, 2013 - 01:03 PM
#41
Did you replace both cams or just the exhaust cam?
  • Krannie McKranface
Posted March 04, 2013 - 02:35 PM
#42
Both
Posted March 05, 2013 - 08:26 PM
#43
The new OEM valves and gaskets came today, as did the thread-in hand-guard inserts and the H4-HID lamp/ballast for the headlight.
Posted ImagePosted ImagePosted Image
  • MANIAC998
Posted March 06, 2013 - 04:07 AM
#44
Krannie, Where can I get those thread in hand guard inserts? They are exactly what I'm looking for! Thanks!
  • JDLowrance
Posted March 06, 2013 - 11:50 AM
#45
Pro Moto billet also lnown as Fastway.
Got a set sitting on my bench just waiting to go in.
Posted March 06, 2013 - 02:59 PM
#46
As JDL said, Promoto Billet/Fastway.
There are several companies that make Nylon ones too.
Oh, and I cheated.
Those are YZ250F parts shown there......
Don't those springs look a little small to you.....?
Posted March 06, 2013 - 05:09 PM
#47
If the piston really is that small, then odds on the cylinder is gonna be oversize (and you've already noted the marks where the rings stop at TDC & BDC) so a hone will do nothing to improve the clearance issue, and you need a re-plate and hone back into service limits
All of the cross hatching is still visible, everywhere.
  • Cube Steak
Posted March 06, 2013 - 07:01 PM
#48
Me like em build threads ! :thumbsup:
Posted March 11, 2013 - 05:19 PM
#49
OK, the wrong valve springs came, so while I wait for those, it's time to re-grease the pivoty-stuff....
  • jcbikes
Posted March 13, 2013 - 06:39 AM
#50
Any tricks to getting out the swing arm axle that goes thru the frame? Mine would not budge and I did not want to ruin the threads on the end.
Thanks.
Posted March 13, 2013 - 11:45 AM
#51
Thanks.
If you have never removed it before, it might be tough to get out, with all that corrosion.
I always re-grease everything when I buy it, new or used, so I don't usually have a problem.
Unfortunately, brute force and a torch might be your only solution.
Double nut the end of the swingarm axle before pounding on it.
  • jcbikes
Posted March 13, 2013 - 02:41 PM
#52
Thanks for the info. will try the double nut. good idea.
  • MANIAC998
Posted March 14, 2013 - 03:13 AM
#53
Also, using a good penetrating oil the night before removal might help loosen things up. I prefer PB Blaster.
Posted March 14, 2013 - 05:48 AM
#54
Oh yeah, that stuff is good. Don't get it on paint or your hands. It will melt a finger....
Posted March 14, 2013 - 01:20 PM
#55
Cylinder is ready to go....Posted Image
Posted March 15, 2013 - 01:20 PM
#56
Re-sprung and Re-valved forks, with full covers
Posted March 15, 2013 - 06:43 PM
#57
Tension er
Head, after glass beading and before seat grinding
New piston, rings, wristpin
Edited by Krannie, March 15, 2013 - 06:43 PM.
Posted March 16, 2013 - 07:10 PM
#58
Well, not good news.
The oil that was drained from the crankcase was highly contiminated, very low on oil, and full of metal...........
We got less than 17oz of oil from the motor........
This would explain A LOT about the pre-mature wear of the piston, the near-siezing of the wrist pin, and the very stiff shifting.
Hopefully , the crank, shift drum and shift forks are not in too bad of shape.
:thumbsdn:
Posted March 18, 2013 - 02:49 PM
#59
What an A** hole...........
Obviously maintained by a blind paraplegic...
Posted March 19, 2013 - 05:17 AM
#60
Ooooh, the 2007 YZ suspension is now installed. Re-sprung (6.4/.49) and re-valved (AS Racing).
The skid plate was removed so the timing chain could be accessed, and replaced; then the motor goes back together.
YZ fork with the very trick triple clamps!
Diverse Racing rear spring
Oh, and the part I kind of forgot about since I bought the bike: Tagasako Excel Pro hubs, and Exel HD spokes, front and rear (they need a bath, huh...)
