Homemade Silencer
16 replies to this topic
  • jcheatham
Posted February 06, 2013 - 06:20 PM
Hello I have a 2000 YZ295 and LOVE IT! Before I sent off my head and cylinder I hade the SST pipe and Powercore 2 exhaust set up. Seeing that SST was the worst thing I could possibly have on with my EG295 I had to store it. I switched back over to my full stock set up since my fmf silencer had holes all around it from corrosion. Im going to try and make my own silencer and a carbon fiber tip since I have always wanted to see how carbon fiber is. Im currently going to school for machining so making brackets and such wont be a problem. My question is, does the actual diameter of the silencer make a difference, I know length does. Also the tube in the inside does the size of that matter and do the size of all those holes make a difference. I would like to get this to perform like stock and mabey better. I might have missed some things. any input will help me with my future project!
  • kiwi86
Posted February 06, 2013 - 10:53 PM
I would be quite interested in your results, if you google search Gordon Jennings 2 stroke tuners handbook you will come across a downloadable PDF file on all things to do with two stroke engines. That will have formulas for working out the dimensions for a silencer.
Keep us posted on your progress!
  • BDubb106
Posted February 07, 2013 - 04:00 AM
Im looking forward to your results as well! Should be interesting to see what the average guy can make with some off the shelf materials
  • yamaha7442
Posted February 07, 2013 - 04:43 AM
Everything will make a difference.
Length, diam, packing material, hole size
in the perforated inner core.
...small holes in the perf will be a lot
louder, as well.
Copy what you already have would be a
good place to start
...m4 exhaust makes an adjustable silencer with
different size tips for the outlet, and the
power can be shaped / makes a big difference
just by that little change, and will affect jetting /
heat in the pipe and motor.
...burnt out packing can also lose as much as
2 to 4 hp on a dyno run, depending on engine size, and also make the engine
run like crap, so keep it freshly packed
Edited by yamaha7442, February 07, 2013 - 04:47 AM.
  • souliog
Posted February 07, 2013 - 10:54 AM
I need to take a few pictures, but I was able to cut 4" off the stock silencer and make a shorty out of it. Works good on my 250.
  • prplhzei.t200
Posted February 07, 2013 - 11:02 AM
Whats a YZ295?
  • jcheatham
Posted February 07, 2013 - 12:10 PM
Whats a YZ295?
a YZ295 is a YZ250 bored out to a 295. Eric gorr is one of the best!
  • BDubb106
Posted February 07, 2013 - 01:23 PM
Not a stock silencer, but I broke my shorty and had this sparky laying around. Needless to say, it is no longer a sparky. Same concept though... I cut it down so it is now 6 inches long.
Edited by BDubb106, February 07, 2013 - 01:24 PM.
  • jcheatham
Posted February 07, 2013 - 05:50 PM
that looks pretty good mabey I should just buy a cheap silencer on eBay and just cut it down a bit. And then make some carbon fiber tips
  • BDubb106
Posted February 07, 2013 - 05:57 PM
would probably be cheaper, and get you much closer to a well performing product than experimenting. Just keep in mind. The shorter the silencer the more bottom end, less top end.
I just use this for the more SX oriented tracks where you never get above mid throttle because the runs are so short so I dont need the over rev. Otherwise I use the off the shelf shorty, or standard silencer so you should def experiment with lengths. I usually find banged up silencers on ebay and cut/ weld them just to experiment. I have not paid over $10 for a silencer and I have a full shelf of them of all diff lengths. Most of which I have never used, but plan on playing with this summer.
  • Chill_MotoX
Posted February 08, 2013 - 08:07 AM
It would be cool and maybe easier if you can make a can and just have it so that can utilize the enduro engeneering spark arrestor end cap... Also seen lexx carbon fiber tips but not sure if it's for the 2 stroke...
  • kiwi86
Posted February 11, 2013 - 09:57 PM
Any more progress?
  • poldies4
Posted February 12, 2013 - 03:48 AM
Great idea! I might do this myself...
  • jcheatham
Posted February 12, 2013 - 04:38 AM
Any more progress?
not much unfortunitly. I've been looking around and thinking its not about length, but volume. I dont know if its true or not but it makes since. More volume the more top end and the quieter it will be.
  • jcheatham
Any more progress?
  • kiwi86
Posted February 12, 2013 - 10:07 AM
I read on another thread that a short silencer will increase bottom end. That kind of flies in the face of what I thought was the case with intake/exhaust tracts, that you make them long and skinny for bottom end, and short and fat for top end.
http://www.thumperta...ns#entry8365640
Edited by kiwi86, February 12, 2013 - 10:21 AM.
  • BDubb106
Posted February 12, 2013 - 11:07 AM
yea, you have it backwards.
3 points of Spooge by CaptainKnobby
  • Hot  60 replies
How low can a dirt bike be lowered? by Numsa Hul
  • 11 replies
Yz250 woods questions by XRalways
  • Hot  48 replies
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
02 YZ 125 and 04 YZ 250 Compatibility by TPA-MX
  • Hot  27 replies
