Diagnosing a problem
4 replies to this topic
  • tdayyz450
Posted February 05, 2013 - 05:00 PM
I just bought an 04' yz450f.I had a mechanic service the bike yesterday.First it wouldn't idle.,he cleaned the carb changed the plug and changed the oil.When he pulled the drain plug only a quarter quart came out and he said it was gear oil.It was milkly I thought it was a head gasket.He put 3 quarts of oil back in.I read later that it only takes 1.1 quarts to fill it when dry.I then started the bike and old oil was streaming out of a bolt on piece next to the head.Is this a fixable problem,or was I scamed by the seller.I need help.....TED
  • DC_Excitement
Posted February 05, 2013 - 05:08 PM
i believe there are 2 drain plugs on the 04?
and maybe the bolt to check the oil pressure is loose?
i wouldent go back to that mechanic.
Posted February 05, 2013 - 07:41 PM
That particular mechanic should go back to installing tires on cars.
The drain plug in the crankcase will only drop about 6 ounces after the bike's been run for a couple of minutes. There's a drain on the front of the bottom of the frame downtube that will drain the rest. Here are the details on the oil change:
http://www.thumperta...660#post8765660
...on the oiling system:
http://www.thumperta...903#post5221903
and links to download a manual:
http://www.yamaha-mo...uals/index.aspx
http://www.yamahaown...ook.com.au/?r=0
Don't know what bolt you're talking about, but with 3 quarts in, it should be streaming out of someplace.
  • YZPaGuy
Posted February 06, 2013 - 02:47 PM
This is the first time I have seen grey mess up this bad! The person that did that oil change is no mechanic! LOL. He would probably put 150 psi in each tire and forget to put the fourth one on!
Posted February 06, 2013 - 03:32 PM
You may have something there.
  • 0 replies
  • Hot  79 replies
