Which synthetic oil to use
24 replies to this topic
  • rhinoracin
Posted February 04, 2013 - 02:27 PM
I know theres probably a ton of threads on this, but I want to know what the best full-synthetic oils are for my 09 YZ.
I feel like I should be running something better than what Ive been using (Yamalube 10-50 semi). Already have a scotts filter too.
Posted February 04, 2013 - 04:05 PM
There are a good many excellent full synthetics available that will legitimately outperform oils not specifically blended to lube BOTH engines and transmissions. My favorites are Amsoil 10w-40 Synthetic Motorcycle Oil (ID# MCF), which is actually labeled for gear lube uses at API GL1, and Mobil1 Racing 4T Motorcycle oil. Each of these has an equivalent 20w-50 product (Amsoil MCV and Mobil1 V-Twin) that can be used in really hot weather when an 50 weight is actually called for.
There is less difference in the ability of most major synthetics to adequately lube an engine than in their ability to both lube a transmission and to survive in that service for any length of time.
  • rotax800
Posted February 04, 2013 - 04:27 PM
Went from yamalube to silkolene to amsoil mcf. Amsoil was a noticeable dif. in how smooth it shifted. I'm stayin with Amsoil.
  • Gunner354
Posted February 04, 2013 - 07:19 PM
Once you do your research on what is actually in oils, Redline is really hard to beat.
  • dirtywardog
Posted February 05, 2013 - 07:52 AM
motul 300v
  • rhinoracin
Posted February 05, 2013 - 09:27 PM
How is Spectro platinum 4?
going with 10w-40...I would get Amsoil but my shops dont keep it in stock...
Posted February 06, 2013 - 07:34 AM
Spectro 4 (syn/petro blend) and Platinum 4 have shown very good results in lab tests.
I should mention two kinds of oils to avoid:
  • Any oil marked API ECII (level two energy conserving. most likely will not see this in any motorcycle oil)
  • Any oil marked JASO MB (these are friction modified oils for engines only, and not for use with wet clutches)
  • sacfelix
Posted February 08, 2013 - 07:26 PM
I just switched over to Amsoil 10w40 from the standard Yamalube oil and I had to turn my idle down because it was revving a little high. Kinda wired.
  • Deepseadan
Posted February 11, 2013 - 07:31 AM
I use motorex cross power 4t 10w - 50 since I got it for almost free. When my supply runs out, I'm back to amsoil. My bikes like it better.
Edited by Deepseadan, February 11, 2013 - 07:34 AM.
  • Deepseadan
Posted February 11, 2013 - 07:32 AM
Sorry double post
Edited by Deepseadan, February 11, 2013 - 07:33 AM.
  • ckny
Posted February 11, 2013 - 07:35 AM
Until you see what's in Maxima oils, especially Extra and Ultra.
  • rhinoracin
Posted February 18, 2013 - 09:07 PM
For Amsoil, is it their 'advanced synthetic motorcycle' oil that people are using?
  • marv02
Posted February 18, 2013 - 09:20 PM
2nd on Maxima oils.
I have been happy with there oil but I use Belray superclean chain lube Only.
Edited by marv02, February 19, 2013 - 06:16 AM.
  • TecateRay
Posted February 18, 2013 - 09:42 PM
Here's a third for Maxima. Through my club we got a tour and lengthy Q and A session at Maxima. I was a fan before and the depth of knowledge and impressive number of performance sports awards there back up all their advertising claims.
My personal experience has also been excellent whenever I use Maxima.
Posted February 18, 2013 - 09:53 PM
Yes. Amsoil product ID# MCF (10w-40) and MCV (20w-50)
  • Gunner354
Posted February 19, 2013 - 07:22 AM
I would like to see virgin oil numbers from Blackstone labs on these two oils?
  • ckny
Posted February 19, 2013 - 09:07 AM
Extra..
Antinomy - over 1000 ppm
Sodium 225
Magnesium 650
Calcium 730
Barium 11
Phosforus 3400
Zinc 2560
VI @ 100c 12.5
HT/HS is in the high 4's for 40wt and over 5.5 for 50wt.
  • Gunner354
Posted February 19, 2013 - 03:35 PM
Extra..
Sodium 225
Magnesium 650
Calcium 730
Barium 11
Phosforus 3400
Zinc 2560
VI @ 100c 12.5
What group of oil is it?
Posted February 19, 2013 - 04:27 PM
Extra is a Syn/Petro blend using esters. Ultra4 is a Group IV/V (PAO/Ester) blended base oil, while everything higher than that in the Maxima line is a Group V. There are more important aspects, IMO.
  • Gunner354
Posted February 21, 2013 - 04:00 PM
Here's what I don't understand about this comment. Redline uses the best oil base stock known to man currently and typically uses a higher percentage of additives than anyone else. It's a win win in my book. I have years and years of practical experience with Redline oils and can't b happier on the reliability and longevity. I'm not saying that other oils won't give good results. I just like to go with a proven top quality oil. Why take a chance?
