WR450 suspension sag for rocks
12 replies to this topic
  • mslow
Posted February 01, 2013 - 05:52 AM
What are you guys that ride a lot of rock using for your sag settings?
I had my suspension resprung for my weight and it feels more like it's ready for a mx track rather than dual sporting.
my riding is about 50% sand and 50% rock. (New Jersey vs PA)
I don't want to respring it again, so any thoughts on compression, rebound or sag settings would be awesome.
Thanks!
  • MaxPower
Posted February 01, 2013 - 06:12 AM
What spring are you running and what is your riding weight?
  • Krannie McKranface
Posted February 01, 2013 - 01:03 PM
You really should not be changing your sag settings for different riding conditions.
Sag is for geometry. You want that to be as close to a constant as possible.
If you change your sag settings for different riding conditions, your over/under steer conditions will change, making you have to re-learn your bikes handling each time you change the sag.
You should be changing your clickers.
Since the WR is not 'un-level' to begin with (un like KX, KTM, CRFR) you don't need to have substantially 'odd' sag settings, just to compensate.
25/100 is a good sag, in order to give you a neutral steering geometry.
Edited by Krannie, February 01, 2013 - 01:04 PM.
  • mslow
Posted February 01, 2013 - 02:38 PM
Not sure on the spring rates, but I know they are aggressive so they can handle a packed bike on dual sport trips.
Seems to me the backing out the compression and rebound should probably do it, it'll just take some time riding and logging.
We're going on a 10 day off road trip and will experience everything from sand to rock gardens, so it'll be good to have the info.
Any of you guys using quick bleeders or anything to make the rebound and compression changes quicker and easier?
  • beezer
Posted February 01, 2013 - 02:58 PM
You have to make sure your springs are correct for your weight before you do anything.
I'm 200 and needed heavier springs on both ends.
I ride the same terrain you do and the stock valving is pretty good.
Most people have 2 clicker settings. 1 for the rocks and 1 for the sand.
  • mslow
Posted February 04, 2013 - 06:54 AM
yeah i had the suspension all resprung and revalved at Custom Axis/Penske Racing, they've always done real good work for me and I know it's done right, I just need to dial it in for the rocky stuff I guess.
Planning on riding again soon and will probably back out the compression a few and rebound just a couple clicks and start the tedious chore of recording all the changes and results...PIA
  • MaxPower
Posted February 05, 2013 - 03:56 AM
If you are telling us you your bike is valved and sprung for a mx track and you are dual sporting your bike Im missing the part that the suspension tuner did the job right.
If you told them you are riding on a mx track then it is not done right and you will need softer springs and hopefully only turns out on the damping adjusters
Sag setting remain basically constant . Its the spring rates and vavling rates that are changed
  • miweber929
Posted February 05, 2013 - 05:27 AM
Don't assume it's done done right simply because they have done stuff for you in the past; suspension is very finicky and it doesn't take much to go from right to wrong, especially when a place sees a lot of one style bikes like MX. Talk to your shop, and have them help you with setup and verify your wants made it into the bike setup or you'll forever be chasing an incorrectly setup bike.
  • mslow
Posted February 05, 2013 - 11:00 AM
no, they (my friend Tony that works there) knows the riding i was planning on using it for, however I think they pushed more towards the stiffer ride because of my riding technique. Not that i'm a maniac or anything, but i tend to push things a little more than perhaps i should.
he asked exactly what my goal was, my point was that i prefer it a bit softer in the rock gardens.
what do you guys generally do to accomplish rocks and sand? ie how many clicks out for each do you usually go?
  • miweber929
Posted February 06, 2013 - 05:24 AM
Then it sounds like your friend (and shop) would be a better resource for setting than we would since they built it and would know how it reacts better.
I'd say 3-4 clicks is what I've done in the past going from a typical "mixed" setup to wanting to "soften" the ride for rocks. But that's a stock setup and honestly it wasn't worth the effort in feel after I was done.
YMMV.
  • mslow
Posted February 06, 2013 - 05:33 AM
Thanks
i've been in touch with him since i started the thread and we're going to work on it once i get there with the bike loaded for an upcoming trip so we can see how it reacts with the added weight.
10 day dual sport trip coming up in a few months...should be fun on the WR!
  • mslow
Posted March 11, 2013 - 05:40 AM
Fellas, What sag numbers are you guys basing your free sag and rider sag on?
I was under the assumption that rider sag should be between 100-105mm. What should free sag be? Is my rider sag accurate?
Posted March 11, 2013 - 12:07 PM
Static sag (weight of bike only) = 20-30mm. I like 25mm
Race sag (add ready to ride rider) = 100-105. I like 100
Yamaha recommends 25/100 to create the steering geometry they intended.
