99 yz 400 have bits left over from carb clean help!!!!!!!!!!!!!
3 replies to this topic
  • paul999
Posted November 05, 2001 - 02:04 PM
removed carb for good clean and found small o ring and washer left over ! didnot see it drop out of anywhere. I think it maybe from air/fuel screw help me!!!!!!!!!
  • sirthumpalot
Posted November 05, 2001 - 03:31 PM
Off of the top of my head I have no idea where those go, but the manual has some pretty good pictures in it. You should be able to tell where they go by looking in the manual.
  • PK
Posted November 05, 2001 - 05:09 PM
I'll bet ya you had your accelerator pump apart. There is a very small O-ring that goes on the bottom. There is a recessed area so you can't miss it. Also, the float bowl has a small O-ring also. I know about the little O-ring, I dropped mine into the garbage can, took me 20 minutes to find the darn thing.
Good hunting,
Pat
  • Drehwurm
Posted November 05, 2001 - 10:15 PM
Servus paul999,
O-Ring and washer sound like fuel screw - there is no washer in the ACP. It is FUEL SCREW - SPRING - WASHER - O-RING!
Michael
