My First WR450F Build!
Yamaha WR450F Miscellaneous Supermoto Yamaha WR450F 2003
87 replies to this topic
  • Krimble
Posted August 01, 2013 - 07:48 AM
#61
Change that to 2003-2009 yz450f and all the wr450f's . The 250s have different diameter headers going into the header but the mufflers will match up depending on header diameter. (sorry about the confusion) But yea. I cant guarantee fitment of EVERY exhaust system but mounting points and where the header meets the muffler should be the same. On my 07 i have a 2003-2005 yz450f procircuit header with a gytr slip on.
Ahh ok, Thanks man! Here are a couple pics of it finished boys.
  • 123devinzz1
Posted August 02, 2013 - 08:14 AM
#62
Looks wicked man. I enjoyed the build
  • MaxPower
Posted August 04, 2013 - 05:10 AM
#63
I was unaware that pipes from the aluminum framed Yamahas will fit the steel framed bikes and have the mounting holes line up.
You are the first person I know that has done that
  • 123devinzz1
Posted August 04, 2013 - 07:46 AM
#64
and if you notice the part numbers for the fmf headers are the same for the 2005 steel and 2006 aluminum. the slip ons have different part numbers because the stock headers have different diameters for the little insert that fmf supplies to use with stock header.
  • Krimble
Posted August 04, 2013 - 01:42 PM
#65
Yeah, but the WR only had the aluminium frames one year later, which was in 07+.
  • 123devinzz1
Posted August 04, 2013 - 01:44 PM
#66
Referring to the yzf
  • SurfaceToAir
Posted August 06, 2013 - 09:12 AM
#67
I just wish I could make my 04 street legal in California. So many enviromental wacko bastards! Got ahold of everything down here.
You clearly haven't tried to register your bike. Its not hard.
For this threads build- those bikes are B A D!  Great work!  I will be using your build for reference!
cheers!
Dustin
  • 96YAMARID3R
Posted August 06, 2013 - 10:48 AM
#68
cheers!
Dustin
Getting a red sticker street legal in california basically imposible.
  • SurfaceToAir
Posted August 06, 2013 - 11:11 AM
#69
Ah, yes- definitely. Sorry, I glossed over the YZ/ red sticker part.  Green sticker is not hard though.
cheers-
Dustin
  • 96YAMARID3R
Posted August 06, 2013 - 11:20 AM
#70
cheers-
Dustin
Yah, green sticker is easy. If I end up out of state for college I will bringing mu bike to make it street legal.
  • Krimble
Posted October 15, 2013 - 04:45 PM
#71
Well I finally got my lazy ass to stop playing GTA 5 and me and my old man we took out the engine tonight. As I thought, the culprit is the connecting rod bearing. The valves look good, but they indicate I will need a re-jet and tuning of the carb, which I planned to do any ways. Did not have time to split the case, but that will be coming in the next few days for sure.
What is a good way to clean heads? Varsol and a toothbrush? :lol:
  • Krimble
Posted October 15, 2013 - 04:46 PM
#72
WTF?! The case is split and look what I have found...  Check to see which gear is missing a tooth. I found the broken piece in the casing. I'm surprised it didn't end in a bunch of loud grinding noise and a seized motor.  :(
  • bikedude987
Posted October 16, 2013 - 06:05 AM
#73
Holy F*&%!  you're both lucky and unlucky there....BTW, is the shift shaft bent!?
  • Krimble
Posted October 16, 2013 - 04:47 PM
#74
I know, that's exactly what I told my friends today. I'm not lucky it broke, but damn lucky nothing happened at all. Yes, the shift shaft is bent. It's only 45$, so a new is going to be ordered.
Also, to anyone that knows. I mesured the ends of one of my shifter forks and one side was .1891" and the other was .1893" Anyone know what is the standard thickness? To me they look good, but I don't know if they are too used up.
  • Krimble
Posted January 18, 2014 - 01:11 PM
#75
No updates in a while.
I wanted to take out my crank, so I could put in new parts I am ordering in the next few days. I needed a flywheel puller first, did a test thread yesterday so I could see if it fits then I would machine the puller, but I was too excited, so I welded up one with the test nut, with my horrible welding skills... :(
Using a 60 ton press.
EEEkkkk....  :foul:
I'm glad a new crank is being ordered. the crank pin must be pretty hard steel, all that pitting on the con-rod and bearing, yet no wear on the pin itself.
  • SAWR450BOY
Posted January 24, 2014 - 02:58 AM
#76
Nice build, keep them coming. :thumbsup:  Pity about the engine issues, but could have been far worse.
  • Krannie McKranface
Posted January 24, 2014 - 06:20 AM
#77
Was that motor ever submerged, or have a blow head gasket?
Those bearings look water logged.
  • Krimble
Posted January 26, 2014 - 05:25 PM
#78
I'm actually not sure about that. It was abused quite a bit when I got it, so it might of been flooded by the previous owner. Almost never got it in water since I have had it.
The old head gasket was fine, it has a new one now.
I'm not sure about the previous owner though.
  • Krimble
Posted February 09, 2014 - 05:44 PM
#79
Checked my cylinder on the CMM and it looks within specs. Keep in mind they are metric dimensions. The second set of measurements are the top of the cylinder, and the last set is the bottom of the cylinder.
  • Krimble
Posted February 20, 2014 - 03:32 PM
#80
Machined some wheels sliders. Not the best color or the prettiest, but you can't beat something you made yourself.
any reason why to get new Beta 450rr instead of wr450f ? by motf
Dirt Bike   Make / Model Specific   Beta
  • Hot  80 replies
05 wr450 oil leaking from fuel tank mounting hole by gee-tee
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • 0 replies
2012 wr450 headlight by donkeyballz
  • Hot  27 replies
Show Us You 2016 WR450f & Mods by chelder
  • Hot  34 replies
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
  • Hot  55 replies
