how can you tell which springs are in the fork or shock?
Started by
goosey
, Jan 30 2013 08:04 AM
7 replies to this topic
Posted 30 January 2013 - 08:04 AM
Pretty sure the front of this bike I bought is too stiff. Is the rating stamped or something?
Posted 30 January 2013 - 08:13 AM
If your really lucky someone will have it engraved on one of the flats. Some manufactures have a code inscribed on one of the flats, such as two wide lines, a space, and one thin line. I believe those marks only mean something to the specific manufacture. To know for sure you need a spring rate tool. You can check your sag numbers on the front just as you would on the back to determine if your rate is close.
The rear shock spring is generally marked on one of the coils for an aftermarket spring. The spring rate tool is your best option. Even a spring that is marked as one rate may actually be one to two rates different than marked.
Posted 30 January 2013 - 10:52 AM
Most of the time you have to take them apart and find someone that can test them. I would call up pro action in Penn. they are easy to talk to and why not as a company that works on them everyday they might give you a hint on how to find out.
Posted 31 January 2013 - 10:18 AM
goosey, on 30 January 2013 - 10:21 AM, said:
I just checked my manual, it doesn't have that explanation at the beginning or the end of the chapter/section. Does your manual cover the '06 250r?
Edited by YHGEORGE, 31 January 2013 - 10:19 AM.
Posted 31 January 2013 - 01:43 PM
Try this calculator, I've seen other ways using measurements but I sucked at math.
http://www.planetspr...?id=compression
