Yz 450 2012 suspension settings
5 replies to this topic
  • tomjoens
Posted January 26, 2013 - 06:29 PM
Hey any body got any good ideas on some good suspension settings to start with for the 2012 yz450. Looking through alot of the mags and ever pro rider has there own idea on where they should start because ever body complains about the front end of the bike in the corners. Also saying that the rear shock bucks to much needed to adjust rebound as such. Just thought I could throw it out there to see what others are running on the front and back.
  • joaquin1296
Posted January 27, 2013 - 04:15 AM
Most important is to have the right springs for your weight. Then set the SAG as most accurate as possible.
US model stock settings:
Front:
LSC: 13 clicks out
REB: 10 clicks out
Rear:
HSC: 1-14 turns out
LSC: 8 out
Rebound: 17 clicks out
  • N2BLUE314
Posted January 28, 2013 - 05:38 AM
I just purchased a 2012 YZ450 as well and have not set up my suspension either. What weight are you basing these settings on. How would I determine the settings for a rider at 190.
  • tomjoens
Posted January 28, 2013 - 08:26 AM
The settings he posted were stock settings
  • tomjoens
Posted January 28, 2013 - 08:29 AM
Im thinking of trying the linkage arm from pro circuit
  • joaquin1296
Posted January 28, 2013 - 02:57 PM
The stock springs. For a 80 Kg rider, in the European model are.
European model
4.6 N/mm front springs
54 N/mm shock spring
US model
56 N/mm shock spring
You can Check the Racetech website. There is a lot of information there.
Keep in mind that the Yamaha is very sensible to SAG and that the weight has be measured always with all the gear on. More or less is around +10kg.
  • 5 replies
  • Hot  47 replies
  • On January 15, 2017
  • Hot  28 replies
  • 0 replies
