YZ - WR fork springs swap
7 replies to this topic
  • zorroz
Posted January 18, 2013 - 05:14 AM
Guys, will 07 - 11 WR450F after market fork springs fit 06 - 07 YZ250F forks ? I have access to 06 YZ250F forks which has lighter spring rate and I have .48 Eibach springs in my 08 WR450F. I was hoping they will swap over. I have used the racetech spring calculator which list the YZ and WR with the same part numbers. I also measured my stock springs and are 5mm long with same diameter.
http://racetech.com/...aha/WR450F/2008
http://racetech.com/...aha/YZ250F/2006
Thank you!
  • Bandit9
Posted January 18, 2013 - 06:03 AM
I don't think they will. 06-07 YZF forks should be the SSS fork, which is a different fork than the open bath WR fork. The springs are different. The WR didn't get that SSS fork until 2012.
  • Krannie McKranface
Posted January 18, 2013 - 06:21 AM
NO
  • GuyGraham
Posted January 18, 2013 - 07:58 AM
According to K-Tech, the YZ250F 06-07 uses 43.5mm OD / 455mm long springs
The WR450 07 - 11 uses the same diameter spring but 460mm long, so you''l need a 5mm spacer to make up the difference
I use the 455mm YZF springs in my WR450 2008 model, along with a 5mm spacer and it works fine
Without the 5mm spacer the spring isn't long enough and you will have no preload on the spring when fitted resulting is excessive static sag
The spacer needs to sit at the bottom of the spring (on top of the cartridge) and is basically just a big washer - I made mine on the lathe at work
I also drilled holes in it to allow the oil to flow upwards as the spring compress, because with out the holes the spacer blokes the oil flow hole in the ledge on the top of the cartridge (that the spring sits on)
  • zorroz
Posted January 18, 2013 - 03:01 PM
Well if my WR450F springs are 5mm longer, they should fit the YZ forks? With a little more spring tension.
  • Bandit9
Posted January 18, 2013 - 04:33 PM
I wouldn't do it. Use the right spring.
  • GuyGraham
Posted January 19, 2013 - 05:12 AM
Was getting confused - I wrote my reply thinking you were putting the YZF springs in the WR forks
So, now I've got my brain into gear and you are wanting to fit your after market .48's from the Wr, into the YZF forks - right?
You are right, you will have 5mm more preload than when they were fitted to the WR forks
Just check that you have 460mm long springs, as the Race Tech website looks like they sell 455mm springs for the WR instead of the OE 460mm length
Edited by GuyGraham, January 19, 2013 - 05:13 AM.
  • TX-SANDMAN
Posted March 23, 2013 - 07:17 AM
- Did you do the swap --- how to they work?
