ThumperTalk
Welcome to ThumperTalk, the largest and most active community of powersports enthusiasts on the planet!
You are currently viewing our site as guest (aka lurker) which gives you limited access to most discussion threads and exclusive articles, as well as restricting your ability to use our powerful site search and other valuable resources.
Joining our community is easy, fast and absolutely free, providing you full access to our extensive discussion thread archive, exclusive articles and special offers, as well as unlimited site searching, private messaging, virtual garage & more!
So, what are you waiting for? Join ThumperTalk now!
If you encounter any problems with the registration process or logging into your account, please visit our 24/7 help section.
Go Back   ThumperTalk > Product and Bike Reviews > Products > Boots
Forgot?
Comment
Review Tools Display Modes
Scott Genius Boots
Scott Genius Boots
Published by Bryan Bosch
12-27-2007
Polymer Protection
The Genius MX Boot is constructed of injection molded pieces of Hytrel® and polyurethane. Both of these materials are characterized by their durability and impact resistance. Using these
materials in the construction allows the Genius MX Boot to protect the lower leg and foot to a level unreachable by its leather counterparts.
DuPont Hytrel
The revolutionary protection and performance of the Genius MX Boot is made possible by the use of DuPont™ Hytrel® in its molded parts. This polyurethane thermoplastic has the characteristics of both rubber and engineered plastics.
Excellent Fatigue Resistance: Hytrel® retains its resistance to deformation even after being flexed thousands of times.
Outstanding Damping Properties: Hytrel® has exceptional energy dispersal qualities, softening hard impacts.
Chemical Resistance: Genius Boots are resistant to most chemicals used in the maintenance and cleaning of off-road motorcycles.
High Impact Strength: The strength of Hytrel® translates into near bulletproof protection.
Stability: Hytrel® retains its flexibility over a wide temperature range, 32º F to 90º F (0º C to 30º C).
SCOTT Pivot System-Combining Strength and Flex
The ingenious SCOTT Pivot System allows the boot to flex while retaining its solid construction. The hinge design compliments the polymer materials, resolving the performance/protection paradox. A boot must provide movement and flex while maintaining solid protection and support. Until now, one factor had to be sacrificed in order to address the other. The Genius MX Boot allows movement without compromising rigidity and strength. The hinge design and Hytrel® material allows the necessary foot articulation required by a rider, while simultaneously limiting ankle motion. Under excessive loads the Genius limits flex, discouraging fractures and ligament strains. This feature also eliminates the need for buckle over-tightening, which is common with softer, leather boots. The unique construction and hinge feature reduce unwanted pressure points.
Weight
Weight was a key concern for the SCOTT design team while designing the Genius. They vigilantly strived to deliver outstanding protection while maintaining a desirable weight. They succeeded in
their goal by keeping the weight to an amazing 4.3 lbs (1950 grams), which is lighter than many industry-leading boots.
Durability
Traditional motocross boots have a very short performance life span. Leather construction loses its integrity with continuous use and exposure to the elements (i.e. moisture, chemicals, temperatures).
The Hytrel® construction of the Genius Boot will withstand all the rigors of hard riding without losing integrity. The Genius will remain sturdy lap after lap, month after month, year after year.
Break-in
The Genius Boot is ride ready. No break-in period is necessary. The intensive research and development allow the boot to fit each individual comfortably. Only some bootie and strap adjustments are required before twisting the throttle.
Patented Technology
The Genius MX Boot is so innovative and groundbreaking, that is has been awarded three worldwide patents for the SCOTT Pivot System, the Brake Transfer Pad, and the Sure-Feel Shifter Pad. (Patent # 000055, #000056, #000057)
Member Review
The Scott Genius boot has a lot in common with the tag-line that I saw recently in a Scion car commercial, "Love it." "Hate it." In reading the comments on ThumperTalk, few seem to be indifferent about this boot. They are either a strict fuction over forum guy or someone that just can't get over the looks of the boot, no matter how well it might function. Because of the strong feelings this boot seems to evoke, I had to give them a try. On the the first day of testing, I was breaking in my new KTM 450XCR-W and I wore my Klim F4 helmet. These, coupled with the Genius boots earned me the affectionate nic name of "Darth Pumpkin". I've been called worse, so off we went.
The Genius boot use an inner bootie with an outer shell. The boot comes with two pair of booties in half sizes to minimize fitment issues. I chose the 10 - 10.5 combo, but it does seem that they run just a hair on the small size. I normally wear a 10, but ended up using the 10.5 booties and even they were just a tad on the snug size. So, if you normally wear the half size, you might consider choosing the next size range up.
As with most shell & bootie designs, there is a bit more work putting the boot on, making sure that shell lower, upper and instep pieces are all layered properly. For example, it wasn't obvious if the upper portion of the instep piece (tongue) was designed to go inside or out of the shell upper. However, once you do it the first time it's no longer an issue.
Each Genius boot includes three wide straps that are very easy to adjust and provide a secure fit. The buckles are metal and snap completely flat inside the buckle body for snag-free performance. Because they snap into place, they aren't coming open on the trail. One required some serious persuasion to open, but with a little use, I'm sure it will loose up a bit.
Once on and adjusted to my liking, the boots were quite comfortable. No pinching, binding or pressure points. My rule of thumb for apparel is that if I don't think about it when I'm riding, it must be comfortable. I was a little worried about the bootie design, as I have a small bone spur on the outside of my right leg, just below the ankle, but the foam donuts on either side of the bootie do a great job keeping your ankle isolated from the hard shell. In terms of break in, there is none. They are ready to ride from Scott.
The footbed is very stiff, so it flexes very little when bouncing through sand whoops and on landings. After a long, hard day riding, your feet will appreciate this. Also, lower shell is very stiff, especially in the ankle area. While the boot's patented ankle pivoting system allows for a very natural fore/aft movement, side-to-side (lateral) movement is extremely limited. This is especially good news for anyone with weak ankles or past ankle injuries
In terms of protection from impacts, this boot is as good as any I've worn. The toe box and ankle appear very strong and upper shell has impact protection on all sides of your calf (including the back, which is often ignored).
There are a few things about this boot that I didn't care for. The first is that the toe profile is a bit on the chunky side. I had some trouble getting my toe under the shift lever, which was sitting about level. Later in the day, I traded bikes with my riding buddy who wears a size 12 boot. I asked him if he was having any shifting troubles and he said no. On another ride, I adjusted the shift lever upward just a hair and it helped somewhat, but I still think the toe profile needs to be slimmed down a bit to completely solve the problem.
The other issue, depending upon where you ride is that the shell when closed has gaps that allow water to reach the inner bootie. Since I ride the desert SW, this isn't much of an issue, but having grown up in the Pac NW, this would be a show stopper for anything but summer riding.
Overall, I think Scott has a great boot here that is comfortable and has a ton of safety built into it. However, I think it needs some further refinement to receive top ranks across the board. My gut tells me you'll see more of these boots on the track than the trail.
Pros
- Looks
- Comfortable & supportive
- Excellent fore/aft movement
- Solid protection
- Easy to adjust straps and locking buckles
- Zero break-in
Cons
- Looks
- Chunky toe box can make for more difficult shifting
- Suited to dry conditions
- Pricey
Bottom-line:
If you ride primarily dry conditions, protection is high on your list of requirements (especially ankle) and you prefer to be a little different, Scott Genius boots should be on your short list.
Extended Information:
http://scottusa.com/
Overall Rating
Value
75%75%75%
3.75
Comfort
87.6%87.6%87.6%
4.38
Quality
90%90%90%
4.50
Performance
80%80%80%
4.00
8 users rated 83% average
Additional Information
Suggested Retail Price (USD)
$499.00
Check ThumperTalk's Price
shop.thumpertalk.com/catalogs/Weste...
Click image for larger version
By k2rider on 01-04-2008, 06:49 PM
I only tried them on (for fun) because I think they are the most hideous thing since the Pontiac Aztec. I can't say I liked ANYTHING about them. They felt bulky and way too much plastic for my tastes. They have to be leftover Stormtrooper boots from the Star Wars era....
I wouldn't wear them if you gave them to me for free!!!
By Croft315 on 01-08-2008, 07:56 PM
Member Review
Value
100%100%100%
5
Comfort
100%100%100%
5
Quality
100%100%100%
5
Performance
100%100%100%
5
Average 100%
i've been wearing the Genius boots since they were avail and i still love them. no complaints here whatsoever.
value - i once heard someone describe them as "knee brace type protection for your lower leg". i agree and $500 isn't too much for protection in this boot's targeted area.
comfort - i've not had any problems here. comfy and quite cool while i was in texas. they actually vent well. the size i got was snug around the whole ankle area at first, then once i removed the optional ankle donuts... i was spot on!
quality - scott... need i say more? highest rating IMO. i've had zero problems besides some sole gouging from my overly-sharp pegs. scott even gave me the benefit of the doubt and gave me new sole pads.
performance - i have to say, i'm getting older and i really appreciate these things taking injuries to the ankle area off my mind (or at least putting it super low on the list). i think they do what they were designed to do and do it very well. they're supportive and after an initial day's riding i couldn't just put on another leather boot and feel very confident.
A+ from me.
By TPARSONS64 on 01-23-2008, 05:33 PM
Member Review
Value
60%60%60%
3
Comfort
60%60%60%
3
Quality
100%100%100%
5
Performance
40%40%40%
2
Average 65%
Scott almost Genius boot
I am a die hard fan of the first gen of Scott boots. When the Genius boot came out, I bought a pair off ebay for 350 bucks. I rode with them to try to get used to them, but I have to hang them up. The protection is top notch, but the performance is not. The boot is too tall and you have to raise your shift lever. Also, unless you have spiderman senses, you can't feel anything, especially the rear brake pedal. If these boots were not as tall and you could feel more through the sole, they would be the boots out there for sure.
By Jordomx on 01-23-2008, 11:08 PM
Member Review
Value
60%60%60%
3
Comfort
100%100%100%
5
Quality
80%80%80%
4
Performance
60%60%60%
3
Average 75%
Scott Genius Boots: A work in progress
I used to wear the original Scott boots way back when so I was looking forward to the latest effort from Scott. However I was disappointed for several reasons.
Pros:
1) Looks! I love 'em.
2) Comfort
3) Protection
Cons
1) Too thick in the toe area. You have to raise your shifter.
2) They let dirt into the booty. This shouldn't happen.
3) Complicated to get on right.
4) The flat surfaces of the hinge structure can get caught on the rear brake master cylinder wedging your boot tightly against the footpeg. You have to twist your foot away from the bike to free yourself. In the process I popped off one of the rivets! This was on the first ride. To Scott's credit they fixed it and said they have beefed up the rivets. I rounded off the edges so it wouldn't happen again.
Bottom line I'm going back to my SIDI Crossfires!
By Champo on 05-05-2008, 03:44 AM
Member Review
Value
60%60%60%
3
Comfort
100%100%100%
5
Quality
80%80%80%
4
Performance
80%80%80%
4
Average 80%
Early days as yet only worn them the once, very comfory on foot. Is a shame though about not the best feeling in the bottom of the foot. Shift'n isn't such a prob as some have said (then again i'm not that tall, lol), but yes the toe could b narrowed a tad all the same. I'll get back to u in week and tell ya how there go'n.
By kevin nichols on 12-10-2008, 06:43 PM
Scott Boots
My son thought the top of the line Gaerne boot was it, until he tried the Scott Genius. With his race sponsorship and other discounts he was able to get them several hundred dollars less than the Gaerne, plus they came with really nice goggles and a t-shirt. He is hard on boots and has trashed several pairs of Alpinestars in the last two years. We are pleased with the protection, durability, and comfort of this product. Fantastic!!!!
By ty53ler on 03-26-2009, 01:00 PM
Member Review
Value
80%80%80%
4
Comfort
80%80%80%
4
Quality
100%100%100%
5
Performance
100%100%100%
5
Average 90%
Scott Genius
Just got my pair of Scott genius boots. When i first tried them on i found that theres a couple different layers which makes them weird to put on for the first time but after youve done it once its easy after that. I havent rode with them on a track yet so i cant tell how well there going to hold water and dirt out. They feel very comftorable the hinge its built on work smoothly, the only thing that feels weird is one plastic piece that rubs on my heel but its hardly noticable. I would recommend these to anyone if you could find them for a better price than the price of 500. i got them on ebay for a good deal so there worth it to me. they do look different but who wants to look the same as everyone, and they dont look as bad as they do in the pictures.
By LaYZ450F on 03-26-2009, 05:26 PM
Member Review
Value
80%80%80%
4
Comfort
80%80%80%
4
Quality
100%100%100%
5
Performance
100%100%100%
5
Average 90%
I have had a pair of these boots for just over a year now and love them. They do take a little of getting use to but they offer the most protection on the market. I have upgraded now and have a pair for sale with new (never installed) replacement soles. I also have two pair of inner booties size 12 and 13. I will take $150 plus shipping. Shoot me a PM if interested
By tnat1 on 01-28-2010, 07:40 AM
Member Review
Value
100%100%100%
5
Comfort
80%80%80%
4
Quality
80%80%80%
4
Performance
80%80%80%
4
Average 85%
Love my Scotts!
I picked up my Scotts online on a blow out sale, i got them for $200 new even cheaper then my Scott sponsorship, I have bad ankles due too old skateboarding injuries, im 43 yrs old and when i get injured it takes forever for my ankles to heal up. I currently was running my Garne Supermoto boots which are modified Sg10s which i do like those boots as far as comfort, protection and performance. So ive been wearing the scotts for about 2 months now and it took about 2 sessions to get used to the feeling of the boots. The shifter area is rather large but i moved my shifter up and it helped alot. The only thing is i have to make more of a concerted effort when i go to shift. Im going to resolve this by getting a hammerhead shifter that is longer and the toe piece is also longer. The boots have rubberized grip pads on the insides which i find very positive when standing and gripping the bike. The protection is # 1 I now feel totally protected when wearing them, ive had some major G-outs and cased a few jumps and have had no issues whatsoever with these, if it was my Garnes my ankles would hav ebeen blown out as i ride on the balls of my feet and with a G-out my ankles go straight down, with the Scott boots the amount of movement is limited in the up down range. Now its no problem i just keep riding as if nothing even happened. They clean up great, the fit is great and they are super light. I think all boots should move in this direction, even the top Alpinstars are probably 90% plastic. If you have bad ankles or dont want to get bad ankles Do yourself a favor and pick up a pair of these boots you wont regret it!
Comment
Review Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Review Review Starter Category Comments Last Post
Complication of Genius 05' LieutLaxitive Off-Road Pictures & Video 24 09-30-2005 10:36 PM
Tom Klippenstein ( A real man of genius) dirty_south400s DR-Z 400 4 07-27-2004 06:06 AM
Gyro is a GENIUS!!! erik DR-Z 400 0 11-10-2001 07:13 PM
Copyright ©2000 - 2010, ThumperTalk, Inc. -  All rights reserved.
ThumperTalk® is a registered trademark.
