| Welcome to ThumperTalk, the largest and most active community of powersports enthusiasts on the planet! |
You are currently viewing our site as guest (aka lurker) which gives you limited access to most discussion threads and exclusive articles, as well as restricting your ability to use our powerful site search and other valuable resources. Joining our community is easy, fast and absolutely free, providing you full access to our extensive discussion thread archive, exclusive articles and special offers, as well as unlimited site searching, private messaging, virtual garage & more! So, what are you waiting for? Join ThumperTalk now! If you encounter any problems with the registration process or logging into your account, please visit our 24/7 help section. |
| CRF150 R/Expert Motocross |
Thread Tools | Display Modes |
Too loud for me..
The bad news is that the new 150 is very loud, the good news (if any) is that it's so loud stock I doubt the aftermarket companies will be able to make it much louder.
Here's my situation: as a pro-class supermoto racer I'm fully aware that wide open exhausts make a bit more power, and I'm certainly a good enough racer to use every teensy bit of my 450's power at the track, but I'm also very aware and upset over noise issues causing track closures and the constant threat of laws banning ORV use on private property. I purchased the new crf150r as a playbike replacement for my beloved 150f..and of course after riding the 150r I had the same initial reactions as everyone else "WOW!" better than I could have imagined, and just exactly the bike I've always wanted as a playbike blah blah blah...umm, well, except for the noise . I have 20 acres of woods laced with about 2 miles of trails and jumps scaled perfectly for these mid-sized bikes and my son's sx65, but even with 20 acres there is no way that my very cool neighbors wouldn't be bothered by this thing, and there's absolutely no way I'd subject them to it.SOOO, since nobody is going to offer a truly quiet quiet exhaust, yet another do-it-myself scabrication project begins. The goal is to get very close to totally stock crf150f sound output while keeping as much of the R model's throttle steering/wheelie on demand kick ass power as possible. Enjoy. Step 1: testing. We used a straightaway to test the stock sound. We made several passes in 4th gear, under load, adjusting our aproach speed so that we'd be in the peak power and truly truly WFO while passing the meter which was placed 50 feet to the side of the track. (a reasonable test, since several of our trails come within 50 feet of a property line) 95dbA!!, yes ninety-F'n-five decibels...at 50 feet!?..good god that IS a very loud minibike. Seems as loud as a 250, only worse since it's almost always pinned. Step 2: Take it apart. not much to see here, standard OEM fare, minimal perforation, minimal packing, 1.4" I.D. straight through with a slight curve in the endcap. Step 3: Try somethin else. We'll keep it simple and try the basics first. a) Increase exposure to the packing material..I've had great luck using expanded metal to replace stock perf-tubes, it's never ever failed me, and the packing does not burn out as fast as you'd think even on a 450. b) Reduce diameter. Using the new perforated section to taper down, I went from the 1.4" input down to a 1.1" output. c) Divert the flow. it's been my experience that if you let any exhaust flow pass straight through then a great deal of noise will go right along with it..so i've created a diffusing chamber within the last 1.25" of the silencer shell. Now the exhaust flow (which has already seen lots of glass and had its tunnel narrowed a bit) is split by that cone on the center of the back wall and forced to take the long way around to the two (0.7" dia.) exits. Step 4: Results? Same test procedure described in step 1.....85dbA. Ten decibels less!..oh, and the bike felt like it hadn't lost any power. Hmmm, off to the dyno.. All of these runs are corrected hp using the stock knobby..the stock run was done when the bike was new (not broken in yet) out of jetting curiousity, but we did not change the stock jetting. I've seen other stock dyno runs posted (20.7hp broken in with knobby, and BBR got 23hp using a smooth street tire) so my bike seems to be right in line with those other figures. Maybe these exhaust mods lost 1/2hp?..maybe nothing?..either way, -10dbA is much much quieter and also a far greater reduction than you'll ever experience with the typical "optional quiet insert" . Unfortunately, I think WFO85dbA is still too loud for my property so I'll have to try some other solutions, but it's a great start. -Michael |
Re: Too loud for me..
Great post Mike.
How is the pitch, does it still sound like it's got some balls. |
It sounds really really good...balls-a-plenty. Crudely splitting the flow like that I expected it might sound a bit raspy or out of tune, but not at all.
Its just quieter. |
Excellent post.
ben |
Very cool, you should be an assistant on Myth Busters with your skills..
Seriously.. |
Great work and outstanding post Michael.
"another beautiful theory beaten to death by a gang of ruthless facts..." - Tom Hanna (Master Metalshaper) |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| My bikes are too loud.... | bds_surf | KLX/KLR 600/650 | 55 | 03-26-2007 09:08 AM |
| SuperTrapp Ear Series...too loud or not too loud | Dauntless | XR250/400 | 4 | 10-25-2005 10:40 AM |
| Too Loud? | AZBURP | XR600/650 | 10 | 11-19-2004 01:44 PM |
| Too Loud! Need Help! | Uncle_GB | 250-530 EXC/MXC/SXC/XC-W/XCR-W (4-Strokes) | 4 | 04-14-2004 10:30 AM |
| TOO LOUD! | 666chef | WR/YZ 250F | 10 | 12-21-2001 06:13 AM |
