ThumperTalk
Welcome to ThumperTalk, the largest and most active community of powersports enthusiasts on the planet!
You are currently viewing our site as guest (aka lurker) which gives you limited access to most discussion threads and exclusive articles, as well as restricting your ability to use our powerful site search and other valuable resources.
Joining our community is easy, fast and absolutely free, providing you full access to our extensive discussion thread archive, exclusive articles and special offers, as well as unlimited site searching, private messaging, virtual garage & more!
So, what are you waiting for? Join ThumperTalk now!
If you encounter any problems with the registration process or logging into your account, please visit our 24/7 help section.
Go Back   ThumperTalk > Technical Articles & Tips > Body
Forgot?
Closed Article
Article Tools Display Modes
Seat Cover Install
Published by prwler
04-14-2006
Seat Cover Install
Here's what you need.
1. Small flat blade screwdriver
2. Needle nose pliers
3. Staple gun and staples 1/4 or 3/8 will work
**Buy or rent an electric stapler**
3. Hair dryer
**Not required but it helps**
Click image for larger version
Clean you seat, just don't get it too wet (foam will swell)
Check fit to make sure you have the right cover before taking off the old one!
Remove staples
ID:	783Click image for larger version
Check your foam for damage, repair with contact cement
Start with the top (tank) area of seat, put in a couple of staples
Work your way down the sides pulling tight and stapling, if you have a few wrinkles, remove the staples in that area and smooth out. This is where a hair dry comes in handy. Warm up the seat cover, stretch it into place, and staple it. As it cools, the material will shrink making for a nice tight fit.
***be careful not to heat it up so much you melt the plastic***
When you get most of the way done put the seat on the bike and check fit, the tank may pull or push the seat and cause a wrinkle
Hear again, remove a few staples and stretch and re-staple
When you done you should not be able to pinch up the cover
Install seat, it should look smooth and tight
Now go Ride !
Article Tools
Show Printable Version  Email this Page
Featured Articles
Closed Article
Article Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Article Article Starter Category Comments Last Post
Seat Cover Install... 125shifter CRF450R 7 11-17-2008 07:43 PM
Seat Cover Install Help calvin71 General Dirt Bike Discussion 10 04-11-2006 02:52 PM
Seat cover install ShibbyZ General Dirt Bike Discussion 10 01-02-2006 11:01 PM
Seat cover install fit2btied DR-Z 400 3 11-05-2004 08:17 PM
Seat cover install echobch XR/CRF 80-200 2 01-21-2003 06:04 AM
Copyright ©2000 - 2010, ThumperTalk, Inc. -  All rights reserved.
ThumperTalk® is a registered trademark.
