ThumperTalk
Welcome to ThumperTalk, the largest and most active community of powersports enthusiasts on the planet!
You are currently viewing our site as guest (aka lurker) which gives you limited access to most discussion threads and exclusive articles, as well as restricting your ability to use our powerful site search and other valuable resources.
Joining our community is easy, fast and absolutely free, providing you full access to our extensive discussion thread archive, exclusive articles and special offers, as well as unlimited site searching, private messaging, virtual garage & more!
So, what are you waiting for? Join ThumperTalk now!
If you encounter any problems with the registration process or logging into your account, please visit our 24/7 help section.
Go Back   ThumperTalk > Technical Articles & Tips > Engine / Clutch / Exhaust
Forgot?
Closed Article
Article Tools Display Modes
How to Port Your Engine
Published by 99wr400
01-20-2005
I'm not responsible in any way if you hurt yourself or ruin/damage your motorcycle. You've been warned!
Here's how to port (increase the airflow) of your cylinder head. You can do it yourself this way or spend $250+ for similar results. All you need is about $20 dollars for tools and the skill to take off your cylinder head or cylinder if you have a 2-stroke.
Part I
Step One:
Buy a small file set (swiss cut preferably) "needle" files about 5 or 6 inches long. You should be able to get a set of 6 for about $7 dollars at your local hardware store. The cheap ones will work just fine.
Step Two:
Take off your cylinder head and clean the intake and exhaust ports with solvent (ports, not valves, although you can clean those if you would like).
Step Three:
Look inside the intake port as there will likely be some small deformities (they look like lumps, but not very high) on the sides on the port. They will probably run in a line, the textured surface of the intake port is normal. It allows the fuel and air to mix because of the slight turbulence around the walls of the port.
Step Four:
With adequate lighting, choose a file that will fit the area with the deformity you would like to smooth out. You just need to bring the casting deformity down to be level with the rest of the sides of the port. Slowly file the deformities away, until they are gone. DO NOT POLISH THE INTAKE PORT.
PART II
Step One:
Exhaust porting. Clean out carbon build up with solvent and a fine scotch brite pad or a green one if you want to save time.
Step Two:
Choose a file, and remove the casting flaws (deformities) in the exhaust port.
Step Three:
When the flaws in the EXHAUST port have been removed, you may polish the port with sand paper. Make it as smooth as you would like. You can also match the exhaust port to the header and gain a few extra horsepower just from that.
Good luck and remember that you will be doing this at your own risk. I followed these steps and it helped my bike work a little better. It also worked well for a Yamaha dealer mechanic's KX250. This technique worked well for both 2 and 4-strokes.
Article Tools
Show Printable Version  Email this Page
Closed Article
Article Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Article Article Starter Category Comments Last Post
Small port or Large port piston design for Supermoto??? gospeedracer51 Suspension 0 07-18-2005 06:43 PM
Thumper Racing 660 Kit....to Port Or Not To Port???? EliJoe XR600/650 19 05-16-2005 09:48 PM
To Port or Not to Port? EliJoe CRF450R 8 02-27-2005 05:15 AM
Well, I had to port it..... ToaDsiX XR/CRF 80-200 0 10-15-2004 09:44 PM
broken collar on engine exhaust port? RR@ARS DR-Z 400 8 02-09-2004 06:28 AM
Copyright ©2000 - 2010, ThumperTalk, Inc. -  All rights reserved.
ThumperTalk® is a registered trademark.
