ThumperTalk
Welcome to ThumperTalk, the largest and most active community of powersports enthusiasts on the planet!
You are currently viewing our site as guest (aka lurker) which gives you limited access to most discussion threads and exclusive articles, as well as restricting your ability to use our powerful site search and other valuable resources.
Joining our community is easy, fast and absolutely free, providing you full access to our extensive discussion thread archive, exclusive articles and special offers, as well as unlimited site searching, private messaging, virtual garage & more!
So, what are you waiting for? Join ThumperTalk now!
If you encounter any problems with the registration process or logging into your account, please visit our 24/7 help section.
Go Back   ThumperTalk > Product and Bike Reviews > Products > Rider Accessories
Forgot?
Notices
Rider Accessories Hydration packs, gear bags, back packs, etc.
Comment
Review Tools Display Modes
VholdR Camera
VholdR Camera
Published by Brian Wilson
12-20-2008
VholdR (vee-holder) is the go-anywhere do-anything wearable camcorder that SHOOTS your life in motion. And through VholdR.com, you can SHARE it with an entire world of action life stylists just like you.
VholdR mounts to nearly anything, from helmets to handlebars, roll cages to bull horns. It captures TV quality audio and video to a MicroSD card, and it's abuse proof. No tapes, no cables, no kidding.
Member Review
First Impressions
Straight out of the box, the first thing I noticed was the size and weight. At under 5 ounces and less than 5 inches in total length, it's hard to remember you're even wearing a camera on your helmet. Once I got past the initial "cool" factor of the VholdR, the true simplicity and beauty of it's design starts to shine through. With an aluminum housing, this thing is tough enough to handle mud flying, small tree branches, and just about anything else you're going to throw at it. And with it's simplistic two button controls (on/off power button and a stop/start record switch) it's sure to be a breeze for even the worst technophobe to operate.
Mounting
The VholdR uses a rail mounting system (TRail). The camera comes standard with a weatherproof adhesive pad mount that works great on any flat surface, or slightly contoured surfaces like the side of your helmet. The mount rotates 360 degrees allowing unlimited height adjustment angles. There is no side-to-side adjustment so it's important to position the mount on your helmet correctly to ensure the camera is pointing where you want it, however thanks to the built in dual aiming lasers, positioning the mount is a breeze. I found the aiming lasers to be one VholdR's great features that help separate it from other cameras on the market. When activated, the camera sends out dual laser pointers that allow you to easily aim and level the camera. This makes mounting in the correct position a snap, and removes all guess work of where the camera is pointing.
Aside from the standard flat surface mount, VholdR also offers several optional mounts that can be purchased separately. Including vented helmet mount (such as a bicycle helmet), goggle strap mount, and handle bar mount.
Use
Before heading out to capture the action for the first time, the 2 hour battery needs to be fully charged. Just plug in to any USB port, and go check out some of the user uploaded videos on www.vholdr.com while you wait. Additional batteries are available from VholdR, so for the hard core rider that wants to record the entire day, that won't be a problem. However, you will also need to purchase additional SD memory cards. The VholdR comes standard with a 1GB SD card, which is good for about 50 minutes of recorded video. But a maximum of 2GB cards are supported and available directly from VholdR or just about any store that sells computer accessories, cameras, film, etc. and can be had for as little at $15-$20.
Now that the camera is charged up, operation is a breeze. There are 3 LED indicator lights (memory usage, battery power and recording status). And while the lights are simple and easy to understand, I found them to be very difficult to see in the daylight (especially the recording indicator). But to be fair, it's not like you can see the lights when the camera is strapped to the side of your helmet anyway.
Once the camera has been powered on, to start and stop recording there is a large slide switch on the top of the camera housing. The switch is huge, and very easy to operate with riding gloves. Slide the switch forward, the camera beeps once, and you're recording. Slide the switch towards the back, recording stops and you hear two audible beeps indicating recording has stopped. The large switch combined with the audible beeps makes for easy operation. It's so simple to operate I had no trouble turning the camera on and off while riding, in fact I've had goggle lens tear-offs that were harder to use than the VholdR.
The Video
VholdR includes free video download/upload software for downloading videos from the camera to your PC or Mac. You can organize, tag, clip, and even upload videos to the VholdR website to share with the world. But if you're in a hurry to see yourself in action, just plug the VholdR into any USB port, and windows will recognize the SD memory card allowing you to download and view your video with no special software required.
The 640x480 30fps video was quite impressive compared to other helmet cameras I've seen. The picture is crisp, and steady without excessive shaking. Colors are vivid, and best of all the 90 degree viewing angle lens captures a wide area so you don't miss that great shot of your buddy taking a header over the bars.
While the video quality of this camera is excellent, I found the waterproof microphone to be far too sensitive. Even when covering the microphone hole with tape, the wind noise was overwhelming, and it's obvious the engine noise picked up by the mic was overloading it. VholdR is aware of this, and plans to address it in later versions of this camera.
VholdR Desktop
Another great feature that sets VholdR apart from the competition is the free VholdR Desktop software (for PC & Mac) that is included with the camera. The software makes downloading, viewing, clipping, and sharing your videos fast and simple. You can organize your video library, watch your videos in full screen, tag your videos with descriptions, dates and locations, and best of all you can upload your videos to www.vholdr.com for free and share them with your friends and family. All from one, easy to use application.
Check out some footage from my VholdR test here.
Conclusion
Gone are the days of carrying a bulky camcorder connected with wires to a bullet camera on you head. Even mini hard drive recorders have now become obsolete. With ever shrinking technology, and constantly falling digital media (SD Card) prices, it's finally possible to build an easy to use, compact, all in one helmet camera at a price the average weekend warrior can afford.
Twenty20 has made a solid attempt to capitalize on the new, less expensive, smaller technology available with their VholdR camera.
Overall, I have to give the VholdR a for quality, design, durability, and ease of use. If not for the overly sensitive microphone, I would have given this camera a 5 out of 5 for performance. With a suggested retail price of $349.95 I couldn't call this a great value, but when compared with other less expensive models on the market you certainly do get what you pay for.
Overall Rating
Value
72%72%72%
3.6
Quality
88%88%88%
4.4
Performance
80%80%80%
4.0
5 users rated 80% average
Additional Information
Suggested Retail Price (USD)
$349.95
By trailscout on 12-21-2008, 07:43 AM
just my opinion.............
i currently use the mini-dvr/helmet camera setup from http://helmetcamera.com/
the ability to do away with all of the cords etc and the difficulty of turning on/off the mini dvr was very appealing as i read the above post.
since i edit my videos in windows movie maker and save at a streaming bit rate of 512kbps, i decided to download a VholdR video, convert it to .wmv and edit to 512kbps so i could compare apples to apples.
the comparison when the cameras were both stationary were not all that much different, to me at least.
but when moving down single track with vegetation on both sides, there was a very large difference in quality, again, to me at least. when viewed at 200% size which is where i normally view this size video, the difference in quality became even more noticeable with the VholdR becoming very pixilated.
if you can live with the quality, the VholdR is sure hassle free. for now, i don't really want to go below the quality of the setup i am using.
if the VholdR eventually improves their quality to match what i'm now using, i'll buy one in a heart beat.
harold
By ULEWZ on 12-30-2008, 08:32 AM
Member Review
Value
60%60%60%
3
Quality
100%100%100%
5
Performance
80%80%80%
4
Average 80%
I bought a Vholdr for my son for Christmas, and it works as described, but does have a lot of shake on his helmet. I will see about adding some padding to keep it from shaking (my wife got sick looking at all the shaking video). The microphone is really sensitive and all you hear is wind noise, so I will be adding something to cover the little microphone pin hole on the bottom. It will not shoot long with the stock 1 gig card, so definately upgrade to a 2 gig card. The unit will not beep when turning it off if the card if full, but will beep twice when you attempt to turn it on (nothing records as the card is full). Another battery is nice, so here is the hookup, a Nokia BL-5C battery. I bought one with a charger here.
The genuine Nokia BL-5C battery fits perfect and actually fits a little looser than the stock battery that hangs up.
Last edited by ULEWZ; 01-05-2009 at 06:06 PM.. Reason: Confirmed BL-5C battery fits
By trailscout on 12-30-2008, 04:24 PM
I've been looking at/reading about/and comparing three helmet cam setups. The setup from http://helmetcamera.com/, the http://vholdr.com/, and the http://goprocamera.com/ .
I enjoy uploading videos to my website where friends and family can view them during periods of extreme boredom. I use a satellite for my internet connection that generally averages around 500kbps or so download speed. Double that during low usage hours and maybe even a little lower than 500kbps during high usage hours.
Anyhow, I edit my videos in Windows Movie Maker down to a feed rate of 512 kbps. That is what windows calls minimum broadband and that is what I can generally view. I use Windows Movie Maker simply because I already have it at no cost.
I have edited videos from all three manufacturers mentioned down to the same 512 kbps for direct comparison purposes in video quality using Windows Movie Maker on all three.
Links to the clips are located at: http://ratdb.com/comparehelmetcam.html
They all have the option of extra batteries. GoPro uses simple AAA batteries which are readily available in non-rechargeable or rechargeable.
The entire GoPro unit is advertised as water proof down to 100 feet which is pretty nice. I would think that would hold up to 60 MPH in a heavy rain.
I think the helmetcamera.com model is the most durable in terms of abuse. But it does have all those cords to deal with. I know, I have one. But it also has the best picture, I think. And it can be used with a long list of camcorders. They show a list of what theirs will interface with on their websiet. With a good camcorder, theirs gives the best full resolution hands down. But I only compared using their little mini dvr.
I think the VholdR is the most intriguing and compact. Nice! Unfortunately the comparison at 512 bit rate was not favorable.
I didn't particularly like the GoPro mounted on top of the helmet. It looked just a little too vulnerable for some of the stuff I ride in. But I definitely like the mount for the side of the face guard. Couple of years ago I made a similar mount for a tiny Pentax digital camera with a infra-red button mounted on the handle bar in reach of my thumb. It worked great and since I could actually see part of the camera in my peripheral vision, I was always able to duck my head and protect it from the limbs of brush and trees. And it was not in enough of my peripheral vision to cause any problem at all. Looked a little weird, worked great.
So many toys, so little time and even less money.
harold
By makKX250 on 12-31-2008, 09:59 AM
Member Review
Value
60%60%60%
3
Quality
80%80%80%
4
Performance
60%60%60%
3
Average 67%
I have had two so far. I bought mine through Cycle Gear which turned out to be a blessing. The first unit had problems and I would get the shotgun effect at least once in every 30 minutes of video. After trying different brands of memory cards and after two months of going back and forth with VholdR, I just exchanged the unit at Cycle Gear for a newer version. I was one day before a 24hr endurance race that I had originally bought it for. Two days after I gave up on VholdR resolving (the known) issue and getting the new camera through Cycle Gear, VholdR sent me an RMA. So I guess they will take back defective equipment - you just need more patience then I have.
The new camera functions very well with the only exception of colors getting washed out leaving a greenish tint in very bright light.
The mounting system is quite good and can take a good impact without failing - I have personally tested it!
The microphone problem, as stated in above posts, is quite annoying.
The only improvements I would like is battery life and memory capacity increases and a microphone fix. The memory and battery currently match each other in terms of life (2GB = ~2 hrs, ~2 hr battery life) but it would be nice to double the capacity of both. It never fails the the good wrecks happen after the battery runs out.
By trailscout on 01-01-2009, 04:37 AM
Quote:
It never fails the good wrecks happen after the battery runs out.
wind noise is a problem with any microphone. cell phones, etc. i've tried everything i can think of with the stock mic on my setup. various type wind socks and stuff. the only thing that has worked pretty good in putting the mic inside a top zippered compartment in my ogio backpack.
that cuts out the wind but the engine noise still competes with the exhaust note. i have purchased a shotgun mic to use for special videos but have not tried it out yet. it is supposed to cut out adjacent noise and mostly only pick up noise at a distant that it is pointed at. my theory is to point it backward and hopefully try to pick up what someone riding forty or so feet behind would hear. it's sure be cool to pick up a clean exhaust note. i think that's why so many clips have music.
oh yeah! the wrecks is what it's all about
By albertaguy on 01-10-2009, 10:11 PM
Anyone tried the POV1? I'm looking to buy my first setup. I'll be using it in the dunes so do they make a replaceable lens cover for vhold or pov1 as the sand will likely destroy it after a while.
By NoseLwKTM on 01-23-2009, 07:14 AM
Great Camera
I've got to agree with Brian the VholdR camera is a truly great camera. I usually use mine in the summer on mountain biking trips, but I took mine to Utah on a snowboarding trip and it withstood numerous falls, bumps and jumps. The quality of the footage I took was great as well, and to echo what Brian said, that camera is really easy to use. The one thing you do need to pay attention to is how you mount is BEFORE getting out there. The lasers do help with this but it's good to take the extra minute to make sure the cam is mounted how you want it before you start riding. I highly recommend a VholdR to anyone who is in the market for a helmet camera!
By Bill_P on 01-23-2009, 05:19 PM
The audio quality is the deal breaker for me. Until they get a remote mic, that can point AWAY from wind noise and towards the exhaust the camera is useless for my purposes. Would definlately hope they do that....
By Xtremesport on 01-28-2009, 10:35 AM
Member Review
Value
100%100%100%
5
Quality
100%100%100%
5
Performance
80%80%80%
4
Average 93%
I have tried other helmet cams and every one of them has the same problem with the wind. The VholdR has been the only one I have been satisfied with so far...I take mine out for multiple different things...usually its for biking in San Diego, but I just visited a buddy in Wis. and we went skiing and got some awesome footage. I think of it this way, where theres wind theres gonna be noise...I like the VholdR because its inexpensive and gives the best quality compared to others...they actually just dropped in price to $279 too..great buy
Comment
Review Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Review Review Starter Category Comments Last Post
vholdr camera ??? JR616 General Dirt Bike Discussion 4 12-10-2008 05:00 AM
National Enduro 10-19-08 / VholdR helmet camera vids wr426inAZ Dirt Bike Pictures & Video 6 10-21-2008 06:38 PM
VholdR camera, please help! dirtflea Dirt Bike Pictures & Video 2 06-01-2008 12:39 PM
Vholdr question... McKee3304 General Dirt Bike Discussion 6 05-17-2008 06:38 PM
Helmet camera using home video camera bstanton Dirt Bike Pictures & Video 7 11-07-2007 11:55 AM
Copyright ©2000 - 2010, ThumperTalk, Inc. -  All rights reserved.
ThumperTalk® is a registered trademark.
